Activity Forums Adobe After Effects Help in exporting to Mpeg2 – 4:2:2
  • Help in exporting to Mpeg2 – 4:2:2
    Posted by Bluriie on September 12, 2007 at 6:08 pm
    Hi! Thanks for your time. 🙂
    I’m currently using AE 7 on PC, working on PAL 720×576, 25fps.
    And have problems exporting to MPEG 2 – Chroma format 4:2:2
    My render settings were: Output Module -> MPEG 2 -> Profile: 4:2:2
    However upon export, Chroma format is 4:2:0
    (Btw, does “Profile” mean the same as “Chroma format”?)
    I researched other sites and realised that I need a capture card that supports the YUY2 4:2:2 format.
    Is that true? Is there a plug-in I can download?
    I’m so new to this.
    Previously, I exported all files to QT, but for this job, client requested the above specifications.
    Thank you so much.
    Any help is greatly appreciated. 🙂
    “If you can’t solve it… DISsolve it.” 😉
    Roland R. kahlenberg replied 18 years, 11 months ago 2 Members · 3 Replies
  • Roland R. kahlenberg
    September 12, 2007 at 6:36 pm
    Standard Definition MPEG-2 profiles are 4:2:0. High-Definition MPEG-2 profiles allow for 4:2:2 profiles.
    Profiles are not equivalent to chroma. Although you are right in that profiles are analogous to video sampling.
    I believe that the settings may be querky.
    What exactly were the specs that your client requested?
    And you don’t need to shoot at 4:2:2 to output to 4:2:2.
    Cheers
    Roland Kahlenberg
    https://www.broadcastGEMs.com – Adobe After Effects project files
    https://www.myspace.com/rorkrgbspace
  • Bluriie
    September 13, 2007 at 12:09 am
    Hi Roland,
    Thanks for your response.
    Yes, I thought you need to shoot in 4:2:2 to export in similar setting. However my video is a mixed of stills and video.
    Lets say (*just thinking aloud), if the entire video only uses stills/ photos, so how do you convert a still image animation(progressive) to a 4:2:2 format? Could it be something to do with the Compositon Settings instead of the Output Settings?
    Btw, here’s my output requirement:
    MPEG2
    720×576
    PAL 25 fps
    15 Mbps
    4:2:2 chroma format
    GOP 12
    4/3 or 16/9
    I managed to get all the settings in AE – MPEG2 correct, except for the chroma format setting. Couldn’t find a section which allowed me to make the selection. (thought Profile 4:2:2 was the one, but its apparently not.)
    Once again,
    Thank you for your time 🙂
    Regards,
    April
    September 13, 2007 at 1:07 am
    Don’t worry too much with color profiles. Just know that you can mix different color profiles within a single composition and render to a totally different color profile. If you like this sort of thing, then look into AE’s color management tools, which is more useful to understand.
    Are you outputting to an Alcorn-McBride device for playback of the MPEG-2? If you are then take note that I’ve managed to render to their specs. from within AE. Just give them what you have, perhaps even a 10-second segment to test.
    BTW, how do you look at the profile settings for the MPEG-2 file after a render?
    Cheers
    Roland Kahlenberg
