Activity Forums Adobe After Effects Help in creating a Moire effect in AE
  • Help in creating a Moire effect in AE
    Posted by John Reynolds on August 4, 2009 at 1:16 am
    I know a lot of people in here try to get rid of the Moire effects they might encounter, BUT I am trying to make one in After Effects. Does anyone in here have experience on how to Create a good Moire effect using After Effects?
    Really appreciate your help. I’m wanting to do an effect like in the 1966 TV show intro of The Green Hornet.
    I heard that you can create the effect in AE…but don’t know where to start
    John
    David Bogie replied 17 years, 1 month ago 3 Members · 4 Replies
  • Todd Kopriva
    August 4, 2009 at 3:17 am
    I’ve made some neat Moire patterns while playing with shape layers, such as when setting parameters for the polystar shape type to extreme values or using the Repeater to make a lot of overlapping shapes with small offsets.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • John Reynolds
    August 4, 2009 at 3:35 am
    That’s cool Todd. Do you have any tutorials on it? Or somewhere I can learn and get instructions on how to do my own?
    John
  • Todd Kopriva
    August 4, 2009 at 5:24 pm
    There’s nothing fancy to it. Moire patterns emerge from the intersection of large numbers of thin lines. You can create an animated Moire pattern yourself by creating any two sets of thin curves or lines, overlapping them, and then animating the position of one of them.
    (Of course, the Moire pattern artifacts that we all know and hate come from the intersections of the lines in, say, a tie and the many thin scanlines that make up a television image.)
    I think that you’ll find that using the Repeater or otherwise creating overlapping shape layers is an easy and fun way to experiment with this yourself.
    I just made two copies of a star with several hundred points each and a thin (one-pixel) stroke, so I basically ended up with two disks made up of radiating lines. Then I animated one to move past the other.
    Here’s a screen-grab of the result:
  • David Bogie
    August 4, 2009 at 6:42 pm
    A quick google for MOIRE will return several concise (and over the top techno geeky) explanations of the phenomenon sometimes known as frequency interference. A little bit of knowledge can help you replicate and expand on Todd’s experience with predictable results.
    bogiesan
