Activity › Forums › Apple Final Cut Pro Legacy › Help importing logo from Illustrator to Final Cut Pro
Posted by Voodoo465 on March 21, 2007 at 3:23 pmI am mostly a print designer, and I need to improt a graphic created in Illustrator to Final Cut pro for 720×480, whenever I do it, the quality gets very bad. What is the best way to do this and maintain quality???
Scott
Dan Chapman replied 16 years, 11 months ago 5 Members · 7 Replies -
13
March 21, 2007 at 4:58 pmwhat are your sequence settings it it is DV then most graphics you put on it will look bad.
Rob Womack
March 21, 2007 at 6:07 pmScale the vector image in Illustrator to 720 wide, then import. Or if you have After Effects, import it into AE, then export the timeline as Lossless with an alpha channel.
13
March 21, 2007 at 6:24 pm“Scale the vector image in Illustrator to 720 wide, then import. Or if you have After Effects, import it into AE, then export the timeline as Lossless with an alpha channel.”
that still wont make it look good if he is trying to put it on a DV timeline, graphics never look good on a DV timeline.
Gary Adcock
March 21, 2007 at 6:58 pm[zrb123] “Scale the vector image in Illustrator to 720 wide, then import. Or if you have After Effects, import it into AE, then export the timeline as Lossless with an alpha channel.”
Why not just export the file as a .PDF w/ transparency in illustrator, place it into FCP.
works just fine and maintains the vector info correctly.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows -
Rob Womack
March 21, 2007 at 7:32 pmThe original poster never said how the sequence is set, but if you are having trouble with graphics in a DV timeline, finish the picture edit in the dv timeline, then export it as a self-contained movie, re-import it and place it in an uncompressed timeline and add your graphics there.
Dan Chapman
October 16, 2009 at 7:29 pmHi Gary,
I tried your suggestion, but it didn’t work. First of all there is no PDF export in Illustrator CS3. So I save as PDF, but can’t find with transparency setting. There is no “place” in FCP. So I Import the PDF. And it’s raster.
help.
Dan
