Activity Forums Apple Final Cut Pro Legacy Help importing a logo into FCP
  • Help importing a logo into FCP
    Posted by Saya Hillman on December 22, 2007 at 2:52 am
    Hi there –
    I am trying to import a logo into FCP, but when I import the TIFF, which appears transparent in PSD, it is on a white square background in FCP. Any suggestions on how I can import just the logo, sans white square?
    April
    Alvaro Lanciai replied 17 years, 9 months ago 6 Members · 12 Replies
  • 12 Replies
  • Lee Berger
    December 22, 2007 at 2:59 am
    Try saving as a PNG instead.
    Lee Berger
    http://www.leebergermedia.com
  • Bret Williams
    December 22, 2007 at 3:00 am
    Import the psd instead. You’ll get a sequence. Use the sequence as a graphic or open the sequence and copy and paste the layer of your choice into your current sequence.
  • Saya Hillman
    December 22, 2007 at 3:18 am
    Thanks so much, you are saviors! Worked perfectly. Happy holidays –
  • Bret Williams
    December 22, 2007 at 3:49 am
    Just be careful changing that photoshop file. FCP is no After Effects or Premiere when it comes to linking to Photoshop files.
  • Bob Cole
    December 22, 2007 at 4:15 am
    I agree – PSD has been quite problematic for me. Why do you recommend it?
    Bob C
    MacPro 2 x 3GHz dualcore; 10 GB 667MHz
    Kona LHe
    Sony HDV Z1
    Sony HDV M25U
    HD-Connect MI
    Betacam UVW1800
    DVCPro AJ-D650
  • Arnie Schlissel
    December 22, 2007 at 6:54 am
    April, I would urge you to learn how to add an alpha channel to a .tiff, .tga, .png or.pct. This is an issue that will come up time and time again, and it’s not that hard to create the alpha channel.
    OTOH, you can always save individual layers in a .psd file, and it will keep it’s transparency in FCP. If you’re importing several layers at a time, it’s very convenient. If you’re only dealing with a single logo, it’s a slight pain.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Bret Williams
    December 22, 2007 at 7:33 am
    Oh it imports just fine, but you have to know what you’re doing if you make changes to any of your layers. If they change shape or size, FCP doesn’t recognize that and simply stretches the new layer to fit into the old size.
    But no need to utilize alpha channels since it’s using the layer right from PS. No need to save another file and keep up with it either.
    For one file, it’s kind of a wash. But if you’re building complex bullet point lists, it’s much easier to bring in a big layered psd file instead of multitudes of tiffs or picts or pngs.
  • Bret Williams
    December 22, 2007 at 7:35 am
    You can also bring the psd into FCP, place your cursor in the psd sequence, and press shift+N to create a still. Place the still in a bin. Instant FCP still with perfect alpha. No link back to the original psd either.
  • Saya Hillman
    December 22, 2007 at 4:30 pm
    Totally agree Arnie –
    tried sitting with my PSD manual and doing it, but I obviously did something wrong, as my exports still all had the white square. Will keep trying.
  • Arnie Schlissel
    December 22, 2007 at 7:13 pm
    April, when you look at the alpha channel in Photoshop, you should see the transparent parts as pure black, the opaque parts as pure white, and the semi-transparent parts as grey. What does it look like to you?
    Arnie
