Activity › Forums › Apple Final Cut Pro Legacy › Help, I’m in DVD hell…
  • Mitchji
    June 21, 2005 at 2:33 am
    HI,
    An Inkjet or Thermal printer that prints directly on the disc. Epson makes a couple of Inkjet models. Primera makes a Thermal.
    Best Wishes,
    Mitch
  • Mitchji
    June 21, 2005 at 2:42 am
    Oh, DVD recorder. Try a different brand of DVD recorder. Or maybe a newer model. Do some investigation. There must be an online forum devoted to DVD recorders where members are knowledgeable about compatibility.
    Best Wishes,
    Mitch
  • Bouncing Account needs new email address
    June 21, 2005 at 11:39 am
    Hi Andrew,
    I use SP for the bulk of the dubs I do and they will usually play just fine.
    The only time I get a complaint is when the DVD had an “iffy” burn (bad blank?)
    As a test, next time you get an SP-speed disc back, make ANOTHER dub at SP and try again.
    I can’t see that an LP dub would work “better”.
    It may just be that the TOC or similar was not burned “perfectly enough” on that first dub for the client’s DVD player.
    SP sholud always be the best quality and easiest to read.
Page 2 of 2
