Activity Forums Adobe After Effects Help… I need to make a speeding ball “overshoot” it’s stopping point… STAT!
  • Help… I need to make a speeding ball “overshoot” it’s stopping point… STAT!
    Posted by Jennifer on August 15, 2005 at 3:04 pm
    If any of you expert animators can help me… I am flying in a ball which needs to “overshoot its stopping point” because of its speed.
    How do i set up my keyframes to do this? I’ve tried the bezier functions, but can seem to get it to do what I need. Any suggestions would be appreciated! Thanks.
    Jennifer
    Jennifer replied 21 years ago 2 Members · 2 Replies
  • Scott Spengler
    August 15, 2005 at 3:29 pm
    Jennifer,
    I use brute force to add anticipation and overshoot.
    1. Keyframe your ball from left to right (or wherever to wherever) with linear keys.
    2. Select your second keyframe, copy it, move down 2 or 3 frames, and paste it.
    3. Now go back to your 2nd keyframe and just slide your ball a little towards the direction you need your overshoot.
    Elegant? Not really. But it works pretty well and once you get the flow down it’s pretty fast. Be sure to add a little squash and stretch with your scale or bez warp or mesh warp. Whichever fits your situation best. Fun stuff. Make sure motion blur is enabled and turned up pretty high too.
    You can probably do some searches for an expression that’ll give you some of this, but this is a nice “down and dirty”.
    Good luck.
    Scott
    ps. I like to have the first keyframe set to Ease out, 2nd one set to linear, and third set to Ease in. You’ll need to experiment to find which combo you like best.
  • Jennifer
    August 15, 2005 at 3:51 pm
    Why, thank you! That was exactly what I needed! Have a great day!
    Jennifer
