Activity Forums Maxon Cinema 4D Help – I messed up a program setting
  • Help – I messed up a program setting
    Posted by Moldovan on September 2, 2006 at 1:05 am
    Can anyone help?
    I was playing with the attribute manager, and found on the right-click context menu of the NAME attribute an option called USER INTERFACE; it had 3 options: string, multistring and STATIC TEXT. when I chose it, just to see what it is doing, the entry box to the right of the name attribute disappeared, and it indeed became static text. Now I can’t change the object’s name, nor get it back by choosing the right-click-context menu – it just gives me the context menu of the attribue manager itslef (DOCK, UNDOCK, etc.)
    I’ve searched in the manual and found no answer.
    Reseting the layot also didn’t help.
    Does anyone know how to get things right back again, so I can change an object’s name in the attribute manager?
    Moldovan replied 20 years ago 2 Members · 2 Replies
  • Björn Marl
    September 2, 2006 at 9:16 am
    this is a known problem and currently only solveable by deleting the preferences.
    Cheers
    Bj
  • Moldovan
    September 2, 2006 at 9:28 pm
    Thanks a lot, it helped
