Activity Forums Adobe After Effects HELP: I have put in MORE RAM and it is RENDERING SLOWER !!!
  • HELP: I have put in MORE RAM and it is RENDERING SLOWER !!!
    Posted by Noizzz on January 14, 2006 at 7:40 pm
    I had one gig of RAM DDR2 in my pc (winXP, AE6.5), now I have put in 3 more, so a total of 4gb. And it renderes slower!
    I made a test comp and it rendered for about 10min, now with more RAM it were 13min.
    Does anyone know what it can be? And what are the best settings for memory and cache with 4gb of ddr2 ram ? Has opengl or advanced 3d anything to do with it?
    In xp you can only asign 2 gig to an app. but I read about a switch to boost this up to 3,
    anyone using it? should I? how do I do it?
    A lot of questions
    3gig of ram is just alot of money to have a slower render!
    Thanx for reading
    Mike Smith replied 20 years, 7 months ago 4 Members · 4 Replies
  • Mylenium
    January 14, 2006 at 9:50 pm
    You have to use the /3GB switch, otherwise AE doesn’t even see your RAM because Windows does not see it (so to speak). It’s documented somewhere on Microsoft’s website. You shouldn’t expect miracles, though. It’s quite possible that your renders won’t be any faster since using more than 2 GB on a 32 bit OS only works thru memory addres remapping and – as you may have guessed – this consumes CPU power and memory bandwith. The only real benefit of using such systems really is being able to get longer RAM previews or load more stuff into RAM e.g. in 3D programs (textures).
    Mylenium
    [Pour Myl
  • Derrick
    January 15, 2006 at 8:42 am
    Do you have any form of RAID in your machine?
    Having one slow HDD can slow down renders to since the data needs to be saved to disk, and the disk can only keep up for so long.
    I find I get better results even with just 2 SATA drives in RAID config.
    Maybe I’m smoking my socks, but things do go a bit better !???
    – Derrick
  • Mike Smith
    January 16, 2006 at 10:11 am
    Hi Noizz
    Bascis first: of course you made sure the new RAM modules matched what was already there – let’s discount the obvious!
    Then: can AE address more than 2 gig of RAM on Windows. My answer would be – not on a 32-bit Windows, which is what most are.
    My understanding is that Windows machines running 32-bit versions of Windows cannot address more than 2 Gigabytes of RAM – the other 2 Gigabytes of virtual address space are reserved for use by the kernel and allocated to tasks including managing disc space addresses, input / output of hardware devices, managing computer monitor display, addressing on-cpu registers – and on.
    Of course there are 64bit versions out there without this limit; there are also some versions of Windows Server 2000 / 2003 which use 36-bit address if deployed on special Intel architecture wich supports 36-bit addressing – I believe this is mainly used for large database management systems.
    Could you try taking out 2 Gig, and running your test render with just 2 Gig installed?
    So far as I know the 3 Gig switch was designed for use on the Server series of Windows op systems, not for XP. Use with XP is designed only to allow developers to test device drivers in the Windows Server environment: whether it would leave your system unstable, liable to virtual memory fragmentation, and whether AE would be able to address the additional space, I guess we would have to test, or ask adobe. My advice would be not to go there unless you are a developer.
    I’d be interested to be updated on your progress with this !
    Mike
    This from
    https://support.microsoft.com/kb/q291988/
    A description of the 4 GB RAM Tuning feature and the Physical Address Extension switch
    View products that this article applies to.
    Article ID : 291988
    Last Review : August 30, 2005
    Revision : 14.0
    This article was previously published under Q291988
    SUMMARY
    This article describes the 4 gigabyte (GB) random access memory (RAM) Tuning feature and the Physical Address Extension (PAE) switch.
    MORE INFORMATION
    The /3GB and /PAE switches in the Boot.ini file are to be used with the following products:
  • Mike Smith
    January 16, 2006 at 11:22 am
    Don’t know how I messed up that link … try again:
    Hope this one works …
