Activity › Forums › Adobe After Effects › Help! how was this effect done?
  • Help! how was this effect done?
    Posted by Nicholas Necak on November 6, 2022 at 7:01 pm
    Hey! I’m trying to recreate an effect but can’t figure out how. Could someone please take a quick look at this 7-second clip to help guide me? There are two images. The animation with the students is simple and only involves changing the opacity. However, the underlying layer comes in gradually, and I’m not sure how it was done. What tools in after effects should were used to get this look?
    https://www.youtube.com/watch?v=YNe1VCnRyXE
    Nicholas Necak replied 3 years, 10 months ago 4 Members · 6 Replies
  • Andy Kiernan
    November 7, 2022 at 12:20 pm
    I would assume mattes. create a matte, say, a circle mask expanding on a solid white layer, then use that to matte out another layer with turbulent noise applied, then pre-comp that and use it to matte out a texture layer
  • Nicholas Necak
    November 7, 2022 at 3:05 pm
    Hi Andy, thanks for taking the time to answer. I’m using this AI file and it has texture. Since I’m using this file, do I have to follow all the steps your mentioned or is there a less complex route. Iv’e only strating using after effects this year, so im still leaning the program. Please let me know. thanks
  • Matthew Ross
    November 7, 2022 at 7:37 pm
    You might be able to use the CC Burn Film effect to accomplish a similar look as the transition in the example you posted: https://www.youtube.com/watch?v=1h1Zq7RIO_w
    I agree with Andy that a matte involving a circular wipe and an evolving noise texture would probably get you even closer, but CC Burn Film is in that wheelhouse and is probably easier.
  • Julian Chojnacki
    November 8, 2022 at 1:00 am
    Hi Nicholas,
    Gradient Wipe seems to do the trick. Just make sure to tick “Invert Gradient”
  • Nicholas Necak
    November 10, 2022 at 4:32 am
    Thanks Julian! It looks like it did the trick!
  • Nicholas Necak
    November 10, 2022 at 4:33 am
    Thanks matthew! I’ll check out the video.
