Activity Forums Broadcasting Help…How to view MXF file’s embedded closed captions
  • Help…How to view MXF file’s embedded closed captions
    Posted by Isadora Leidenfrost on November 8, 2020 at 1:03 am
    Using a Mac and Final Cut Pro X & Adobe Premiere Pro, I have exported an MXF file of my film for Broadcast, which should have embedded the CEA-608 captions, but I don’t know how to confirm that the captions are formatted and showing up correctly. When I open the file on QuickTime there are no captions. When I open the file on a few other different media players, sometimes the captions show up, but have extra lines of code. How do I officially confirm that the file is good to go before I send it to my PBS producer?
    Christopher Smith replied 12 months ago 2 Members · 1 Reply
  • Christopher Smith
    July 22, 2025 at 7:53 pm
    Your frustration is industry-wide, and no one wants to solve the problem with an affordable tool.
    Telestream makes an expensive tool (Switch) which allows you to view MXF files, and even drop in subtitle tracks to verify they line up with audio and video. Switch also displays any of the 608 or 708 caption tracks, and provides info on all the tracks in the MXF file.
    https://www.telestream.net/switch/overview.htm
