Activity Forums Adobe Encore DVD HELP!! Horizontal Banding on moving objects
  • HELP!! Horizontal Banding on moving objects
    Posted by Alan Howard on October 5, 2006 at 8:31 am
    Hi…
    I’m having real issues with horizontal banding in Encore projects…it only affects any horizontal movement within the shot …the footage (which comes from AVID via Procoder) seems to be going in fine… My guess is that it has to be a field order issue as if I take a freeze of a “wobbly” frame out of Encore and import into photoshop then the initial image I see isn’t “wobbly” .. (you can see lots of horizontal “tears” tho).. if I then use Filter / video / deinterlace I get the “wobbly” image back… If it will help anyone diagnose this send your e mail address to algy40@hotmail.com and I’ll happily send you the freeze frames!
    I shoot mainly on a PD150 or Z1 and Sony have told me I should set everything to lower field first. I generally output from AVID as a QT Ref … put that through Procoder which will give me an m2v file…. when I watch the footage on my computer monitor up to this point then it looks fine….. I then import the m2v file into Encore as a timeline and when I watch that on the encore monitor I get the banding ….. I’ve tried letting Encore do the encoding but the same thing happens .. it’s driving me absolutely mad and I know it’s probably a simple thing …. if anyone could help I’d be very very grateful!
    Alan
    Alan Howard replied 19 years, 11 months ago 4 Members · 12 Replies
  • 12 Replies
  • Jeff Bellune
    October 5, 2006 at 1:49 pm
    First, let me say that an AVID –> ProCoder workflow is not very “Encore-friendly”. There are issues and associated workarounds, but life is harder than it has to be.
    Secondly, though, I may have some good news for you. Rather than base your decision on what you see in the Encore preview, burn an RW disc (no coasters) and test the DVD on a hardware DVD player and an interlaced television. For now, keep everything lower field first. You should get silky-smooth motion with no artifacts. If the TV test doesn’t work, then you can investigate other solutions.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Alan Howard
    October 5, 2006 at 2:56 pm
    Thanks for that Jeff but it’s still there on my TV screen! It’s really quite bad and any camera movement looks terrible …… I shoot handheld a lot so it’s a real problem…. Your book looks interesting… What would you say the best route out of Avid is ?
  • Geo Cohn
    October 5, 2006 at 3:05 pm
    Alan,
    QT Ref is the best way. What are your QT Ref settings? Also, are you doing NTSC or PAL? And what are your Procoder settings?
    George
  • Jeff Bellune
    October 5, 2006 at 6:05 pm
    George is on the right track. All of what he asked about would be helpful info. Also good would be what version of Encore you are using.
    -Jeff
  • Alan Howard
    October 5, 2006 at 6:43 pm
    Thanks George ..
    Its a PAL project and not many real choices in QT Ref.. I realise that most of this stuff is irrelevant but I’ll put it all in anyway! here goes
    QT ref settings
    Use marks – yes
    Use enabled tracks – yes
    Default- Digital Mastering
    Flatten tracks – yes
    Fill spaces – yes
    render all video effects – yes
    mixdown audio tracks – yes
    width + Height – 720 x 540 (4 x 3 square pixel)
    Use Network Media References – unticked
    Use Avid DV Codec – ticked
    Now procoder …
    Setting with Procoder … some seem irelevant but I’ll include anyway …
    Source:
    Track Mode – Use all video/flash/text tracks
    Video Frame Size – 720 x 540
    Frame Rate – 25.00
    Video Codec – Avid DV
    Interlacing – Lower/bottom first
    Aspect Ratio Video[4:3],Pixel[1:1]
    Audio – (not relevant!)
    Target:
    I load a Target Preset using Catagory DVD/ MPEG 2 – DVD PAL(Mastering Quality), (that gives me setting of …MPEG 2, DVD, 720 x 576, 25.00fps, 6 Mbps, PAL, MPEG Video, Stream + Wave filter for DVD authoring software)
    I then apply a preset that a friend put in for me .. those details follow…
    Target file splitting
    Choose Spliting method – No Splitting
    Stream Basic
    Stream Format – DVD [MPEG program / Elementary stream]
    Stream Type – Mpeg 2 Elementary Stream
    Video Basic
    Video Standard – PAL 720 x 576
    Interlacing – Lower/Bottom first
    Aspect Ratio Code – 4 x 3
    Quality / Speed – Highest Quality
    Video Bitrate Control
    Bitrate type – CBR
    Video Bitrate – 6500
    Video Advanced
    Put Sequence Header on each GOP – ticked
    VBV Buffer Size (kb) – 224
    Max GOP size – 15
    GOP Structure – Automatic
    Picture Substructure – Always frame
    Use Closed GOP – unticked
    Chroma Format – greyed out
    Intra DC Precision – 10
    Use Strict GOP Bitrate Control – ticked
    Create DVD compatible stream – ticked
    Audio – (notrelevant)
    Interestingly enough I’ve exported a short piece of video and encoded it as I wrote these settings down ….and now that footage is giving strong horizontal bars any time there’s movement … before the footage goes anywhere near Encore… looks like I owe encore an apology! (That’s just on my computer screen tho’ .. I’ll put through encore and watch on a TV!)
    How do those setting look to you?
    Thanks for your time and effort!
    Alan
  • Alan Howard
    October 5, 2006 at 6:44 pm
    Version is 2.0
  • Jeff Bellune
    October 5, 2006 at 7:05 pm
    Hi Alan,
    First, I have to say that I don’t have any experience mixing SD DVCam/DV material with HDV material in the same project. If I were to try that, I would start with the lowest common denominator and create a project that was 720×576 with a PAR of 1.067. Then I would scale the HDV footage to match. My export settings would be DV PAL at the same frame size and PAR. Especially in light of the fact that the end product is to be a PAL DVD, which also has the same frame size and PAR. Interlacing would be set to LFF.
    According to the settings you listed, you chose not to do that. If those export settings work best for you, then I give the nod to your experience.
    Some individual points:
    1. Under Video Basic, you have aspect ratio code set to 4×3. Does that include a PAR of 1.067? It should.
    2. For maximum compatibility with Encore, under Video Advanced you should have Picture substructure set to Field instead of Frame.
    3. Also to have Procoder play nice with Encore, under Video Advanced again, you should tick Use Closed GOP.
    Back to you,
    -Jeff
  • Jeff Bellune
    October 5, 2006 at 7:07 pm
    PS – As an afterthought, is the Z1 footage the only footage giving you trouble? Or does the PD150 footage do the same thing?
  • Vince Becquiot
    October 5, 2006 at 8:30 pm
    All that sure still sounds like an field order issue. Make you your HDV is set to upper field.
    Vince
  • Geo Cohn
    October 5, 2006 at 9:39 pm
    I’m not too familiar with the PAL world, but with NTSC I have found that it is important to specify “Native Dimensions” for the Display Aspect Ratio in the QT Ref setup, not square pixel. This should give you frames of 720×576. Then make sure you set up ProCoder to expect the same thing. I bet this is what’s giving you the “wobbly” look.
    NTSC field order for DV is lower field first. Isn’t PAL field order upper field first for DV? If you get the field order wrong you will get those horizontal “tears” you were talking about.
    George
