Activity Forums Apple Final Cut Pro Legacy HELP HELP HELP with Audio
  • HELP HELP HELP with Audio
    Posted by Dave Roberts on April 14, 2005 at 9:33 pm
    I can’t hear any audio associated with FCP. Everything else on my computer works fine. What happened and how do I fix it. I am a news reporter trying to make deadline and there couldn’t be a worse possible time for this to happen.
    Please HELP
    Dave Roberts
    Shannon Brame replied 21 years, 5 months ago 4 Members · 5 Replies
  • Jane
    April 14, 2005 at 9:44 pm
    Sometimes I can’t hear audio if I don’t render the clip (sequence>render). That usually works for me. Or perhaps the audio isn’t a format supported by FCP?
  • Kevin Monahan
    April 14, 2005 at 9:48 pm
    This is very common…..
    View Menu: External Video > All Frames.
    Connect the speakers to the DV Deck or DV Camcorder and not the Mac.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • Dave Roberts
    April 14, 2005 at 9:53 pm
    Thank you!!! Thank you!!! Thank you!!! Thank you!!! Thank you!!! Thank you!!!
    That has never happened before. I use my computer for editing news stories and this is the first time that has happened.
    I owe you a beer.
    Dave Roberts
    KWWL-TV
    kwwl.com
  • Kevin Monahan
    April 14, 2005 at 10:17 pm
    Geez Thanks!! Make mine a Rogue Brutal Bitter…or anything by Rogue for that Matter.
    Cedar Rapids ROCKS!
    Kevin Monahan
    fcpworld.com
  • Shannon Brame
    April 15, 2005 at 2:16 pm
    you can also switch your easy setup so that it ignores the dv deck but remains in the dv codec. For me its blackmagic dv, it all depends on your card
