Activity Forums Adobe After Effects help help help! How do you freeze a frame?
  • help help help! How do you freeze a frame?
    Posted by Jennifer on June 28, 2005 at 3:34 pm
    I need to freeze a frame and hold it to the end of the composition. I dont understand the help instructions and its not working? Can anyone please explain this???? Thank you for your help!
    Cory replied 21 years, 2 months ago 4 Members · 4 Replies
  • Andrew Yoole
    June 28, 2005 at 3:42 pm
    Apply Time Remapping to the footage layer. A Start and End keyframe will be created for you. Move to the frame you want to freeze on and add a time remapping keyframe. Change it to a Hold keyframe. If the original End keyframe occurs in the visible timeline you will need to delete it.
  • Jennifer
    June 28, 2005 at 3:44 pm
    I thank you! Owe you big time!
  • Or render the last frame (the one you want to freeze) by using “Save Image” and bring it back in as a still.
  • Cory
    June 28, 2005 at 8:35 pm
    well you could use time remaping and set a keyframe on the frame you want to freeze then hit control+ right arrow. to go over one frame then set another ket frame and drag it out to as far as you want the duration of the frame to be.
    Hey, Check out this site freeiPods.com
    Click here: https://www.freeiPods.com/?r=12107535
