Activity › Forums › Adobe After Effects › HELP: Globally Change Mask Path Key Frames
Posted by Sterling Youngman on March 18, 2008 at 11:24 pmHi,
I have a complex mask that I’ve copied from one layer to another to avoid re-keyframing the entire sequence. However, the new layers position/anchor point are different than the first layer’s. So the mask is too low. I’ve been trying to grab all Mask Path keyframes in order to raise all of them at once. I haven’t had any luck. Does anyone know of a way to do this?
Brian Berneker replied 18 years, 6 months ago 4 Members · 8 Replies -
Darby Edelen
March 18, 2008 at 11:38 pmYou’ll need to duplicate the layer that has your original mask on it and use the duplicate as a track matte. You can then move the layer to get the position/scale right instead of the mask.
Darby Edelen
Designer
Left Coast Digital
Santa Cruz, CA -
Sterling Youngman
March 19, 2008 at 12:02 amHi Darby or anyone else out there,
Unfortunately, I can’t use the existing layer as a track matte. The mask shape modifies an existing alpha. Moving the layer so that the mask is in the right place, moves the existing alpha shape out of place.
Any thoughts on how I could move all the keyframes at once? Is it possible to write an expression for the Mask Path raising the Y coordinates or something like that?
Darby Edelen
March 19, 2008 at 12:55 am[Sterling Youngman] “Unfortunately, I can’t use the existing layer as a track matte. The mask shape modifies an existing alpha. Moving the layer so that the mask is in the right place, moves the existing alpha shape out of place. “
Try applying your mask to a new solid layer that is exactly the same size as the footage you already have masked, then use that solid layer as an alpha track matte. If the solid is not the same size as the footage then the mask will end up being smaller or larger (although this isn’t necessarily a big deal since you can just scale your solid layer after the fact).
You’ll also want to enable ‘Continuously Rasterize’ on your solid layer to avoid loss of resolution along the edges of the mask if you scale the layer.
Darby Edelen
Designer
Left Coast Digital
Santa Cruz, CA -
Jonathan Shohet
March 19, 2008 at 1:09 amIf there is additional alpha information on the original layer, preventing you from using its duplicate as an alpha matte, why not just create a new solid layer, copy the mask unto it and then use it as an alpha matte instead?
cheers,
Jon[edit] whoops, sorry, didn’t see that Darby has already answered with the same solution
Sterling Youngman
March 19, 2008 at 1:26 amDarby and Jon, Using the solid layer worked perfectly. Thanks very much for your help. Although, I wish you could make global changes on the matte position. You can do this in Combustion and it would be very convenient.
Thanks again,
Jonathan Shohet
March 19, 2008 at 1:43 amcombustion in general lets you toggle “animate” mode on and off and choose between global changes for a property or individual keyframe changes.
I too really wish this feature would find it’s way to a future version of After Effects 🙂 -
Brian Berneker
March 19, 2008 at 3:11 amI wonder if you might have gotten away with adjusting the position offset in transform…
