HELP! Framerate problem in timeline
I need help on a project ASAP (as seems to be the case most of the time someone asks a question here).
Longtime reader first time poster.
The framerate on the sequence somehow was changed to 23.98 instead of 29.97. When I printed to tape the footage looked awful. Copied and pasted the entire project into a new sequence with correct frame rate but now timing, audio etc. is a bit off or just messed up with jutters in sound or skips and so on.
Big question, is there a way for me to fix my problem and timeline without having to go through the painstaking process of tweaking all my problems. This project needs to be out the door by Monday.
