Activity Forums Panasonic Cameras HELP!! Frame Rate Conversion-EEEEEK
  • HELP!! Frame Rate Conversion-EEEEEK
    Posted by Erick@vbs on March 1, 2006 at 10:26 pm
    I have a client who tells me they shot Varicam 1080P 24 fps (23.98). They then downconverted for offline to DV/DVCam codec at 29.97. Now they’ve brought me a sequence that was cut at 29.97 and they want to uprez and conform back to 24fps. EEEEEEEEEK!!!!
    Is there any reliable solution? Is there any reasonable solution?
    Looking into Panasonic’s Frame Rate Converter plug-in – although I don’t think it was designed for this.
    Thought of uprezing at 59.98 then using “Remove Advanced Pulldown” – but not sure how it will effect transitions and audio sync.
    I hear there is a “Conform” tool in FCP but that it’s clunky, slow, and unreliable.
    HELP!!!!
    Gunleik Groven replied 20 years, 6 months ago 2 Members · 1 Reply
  • Gunleik Groven
    March 2, 2006 at 5:44 pm
    [erick@VBS] “I have a client who tells me they shot Varicam 1080P 24 fps (23.98).”
    It was not shot this way, as the VariCam is a 720p only camera. The 24 fps are made from a pulldownpattern from a 60 fps videostream.
    [erick@VBS] ” They then downconverted for offline to DV/DVCam codec at 29.97.”
    This sounds sorta reasonable, doesn’t it?
    [erick@VBS] “Now they’ve brought me a sequence that was cut at 29.97 and they want to uprez and conform back to 24fps. EEEEEEEEEK!!!!”
    Is this not the point when you recapture the tapes at full rez (from the aj 1200) either through hd-sdi if you need upscaling to 1080 or through firewire if you want to stay in the 720p domain, apply the FRC and render out the final movie?
    Gunleik
    (Who’s only checking if he’s finally starting to understand some of the workflow with the VC)
