Activity › Forums › Adobe After Effects Expressions › help for a project animating text
  • help for a project animating text
    Posted by Dotan Baytman on November 16, 2006 at 10:52 am
    hi there
    i have this project for a web site i need to make a banner with a text
    and i wanna animate the first character of the word to bounce in the screen from the right then stop and then all the rest of the word come in from the right bounce and stop next to the letter
    i looked at the preset but havent seen something that i want
    please help with this
    thanx
    Dotan Baytman replied 19 years, 10 months ago 3 Members · 6 Replies
  • Mark
    November 16, 2006 at 12:08 pm
    Easiest way for this is to create two layers of text. The first will have the first letter, and the other will have the rest of the word. You may have to create your own animation, or take a preset and work it to your needs. Under the animator, in the advanced setting, you can select the animator to use the word instead of by character, thus allowing your second layer to be able to animated as a whole.
    Mark
  • Dotan Baytman
    November 16, 2006 at 12:17 pm
    Ok thanx
    but i have a problem now
    i realised that i need to use a picture of the text they have alpha channel
    but still i cant use them as regular text
    any chance i can animate them to the same animation i want?
    i mean the bounce thing
  • Todd Morgan
    November 16, 2006 at 1:33 pm
    so what you are saying is that the text you want to animate really isn’t text, but an image? can you recreate the text? if so, then you can use the animators and range finders in the text animation section.
    Todd Morgan
    Creative Director
    Freelance F/X Inc.
  • Dotan Baytman
    November 16, 2006 at 2:01 pm
    I cant recreate the text i dont have the fonts and it has a 3D look to it
    what i did was use masks to break the letters and animate the firest letter and the rest of the word it looks ok but still i think i made it harder then it was suppose to be
    any other ideas?
  • Mark
    November 16, 2006 at 2:47 pm
    If it is an image, then maksing and animating by hand or using expressions to animate are your only way to go.
    Mark
  • Dotan Baytman
    November 16, 2006 at 3:19 pm
    Thanx mark for the answer
    do you remember the expresion for cycle the bounce?
    i wanna make the letter bounce for a few frames and then use expresion to animate few more frames
    also i tried to export to swf but the file is too big try to export to flv but i cant see it in flash
