Activity Forums Apple Final Cut Pro Legacy Help Fixing Editor Mistakes for DVD
  • Help Fixing Editor Mistakes for DVD
    Posted by Matt Code on January 19, 2010 at 1:03 am
    I am supposed to make a DVD for a producer/director/editor/DOP…you get the idea… Anyway, here is what he’s done (don’t ask why either…nobody will ever know):
    -Shot in 1080i60 HDV
    -Captured 1080i60 HDV
    -Imported into a 1080i50 HDV sequence
    -Edited entirely in 1080i50 HDV sequences
    -Sent the audio and video files to a sound mixer who sent him back one giant .aif file for the entire video (37 minutes)
    Now he wants NTSC DVD’s, but obviously when I copy to a 1080i60 sequence to export to Compressor the audio doesn’t match.
    To get 1080i60 files to compressor to play on a DVD at 29.97 what would you do?
    Thank you!
    Arnie Schlissel replied 16 years, 8 months ago 4 Members · 5 Replies
  • Shane Ross
    January 19, 2010 at 1:07 am
    Export the piece with audio as PAL, then convert to NTSC.
    Ouch…ouch ouch ouch.
    Shane
  • Steve Eisen
    January 19, 2010 at 1:10 am
    Create a 1080i60 sequence export movie drop it into compressor. Charge the producer/director/editor/DOP accordingly.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Arnie Schlissel
    January 19, 2010 at 1:17 am
    I think you need to reconform his entire film. Make sure that he’s paying by the hour. And get a good sized deposit, in case he decides to walk away before you’re done.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Matt Code
    January 19, 2010 at 1:51 am
    This is what I was afraid of…I think I either have to go back to the beginning or finish as PAL and convert after the fact…
    I can’t think of any other way to get out of it…even if I drop into 1080i60 sequence that doesn’t fix the audio that is timed to 25fps…
    Any other thoughts?
  • Arnie Schlissel
    January 19, 2010 at 2:33 am
    If you have access to his 50i project, then try to copy & paste all the clips from that into a 60i timeline. With luck, you’ll only need to adjust some in/out points. If the audio drifts, you may have to pull it down by 0.1%.
    Arnie
