Activity Forums Apple Final Cut Pro Legacy HELP! Firewire unplugged!!!
  • HELP! Firewire unplugged!!!
    Posted by Hans Mester on June 15, 2005 at 5:13 pm
    Hello all,
    I have accidentally unplugged a firewire disk with clips for an open project. Now, all the media has to be reconnected. For some reason it has to be done for every single clip. (the “relative” path option is turned on…)
    Any chance of speeding this process up a bit?
    thanx for any help
    Shane Ross replied 21 years, 3 months ago 2 Members · 1 Reply
  • Shane Ross
    June 15, 2005 at 5:47 pm
    Highlight all the clips that are offline and then select RECONNECT. Once if finds one, it should find the others . But you say the relative path option is selected. Hmmmmm.
