Activity › Forums › Apple Final Cut Pro Legacy › HELP – Final Cut Studio 3 Upgrade won’t install
  • HELP – Final Cut Studio 3 Upgrade won’t install
    Posted by Brad Bussé on August 10, 2009 at 1:52 am
    I started the install, it got through the first disc and the Sounds 1 disk, and then it came up with an error on Sounds disc 2. So I tried installing again, and now it finishes disc 1 and asks me to put Sounds disc 1 in, but it doesn’t eject the first disc, and when I try to force eject it, it says that programs on the disc are being used. Before install I ran DiskWarrior to rebuild directory and then rebuilt permissions from a clone of the system.
    Zane Barker replied 17 years, 1 month ago 3 Members · 2 Replies
  • Tom Wolsky
    August 10, 2009 at 2:22 am
    What’s the computer? You should contact Apple or go to an Apple store if you have an installation problem. The discs or the drive may be defective.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Zane Barker
    August 10, 2009 at 2:26 am
    Run FCP Remover to remove the old/bad install restart your computer and see if it will let you try again.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
