Help… Final cut is being weird
Hi there.
Im trying desperately to learn final cut in time for a job and im having problems with basic position and zoom effects…
example.
I select the clip I want to zoom in on…
I use the motions tab and I affect the scale of the clip…
I keyframe the scale
but the weird thing is…. when I key frame the scale the position of the video moves away waaaaaaaay down in the bottom right corner and does its scale effect from there… pretty useless..
Ive noticed keyframes in the time remap setting at exactly the point in which this happens… I have no idea why or even how to remove that keyframe… can someone please explain to me why the position of the clip would do this when Im keyframing the scale?
or could someone direct me to some tutorials for help with this issue?
Thank you, it would be much appreciated.
Best Regards
Conan
