Activity › Forums › Adobe Premiere Pro › Help: Field Rate vs Frame Rate – 1080i 50
  • Help: Field Rate vs Frame Rate – 1080i 50
    Posted by Darren Mcphee on February 19, 2014 at 2:03 am
    I’m preparing to shoot a project destined for TV broadcast in China. The spec sheet I was provided asks for 1080i 50 (1920 x 1080).
    I’m a broadcast noob, so I want to get this right. I’m assuming the 50 stands for field rate, not frame rate?
    If my assumption is right, then 1080i/25 (upper field first) would be the correct output for this project?
    Darren
    Darren Mcphee replied 12 years, 7 months ago 2 Members · 2 Replies
  • Tero Ahlfors
    February 19, 2014 at 5:29 am
    [Darren McPhee] “If my assumption is right, then 1080i/25 (upper field first) would be the correct output for this project?”
    Yep. 25fps upper is called either 50i or 25i.
  • Darren Mcphee
    February 19, 2014 at 5:12 pm
    Great, thanks!
