Activity Forums Apple Final Cut Pro Legacy HELP! FCP5 Crashes at StartUp!
  • HELP! FCP5 Crashes at StartUp!
    Posted by Timothy Rasmussen on September 20, 2005 at 11:20 pm
    I just installed the upgrade to Final Cut Studio. All the other apps seem to boot fine, but when I try to boot FCP5 it loads everything until it says “AE Effects…AE AdvantEdge” – then it dumps out and tells me that FCP has unexpectedly quit.
    I’ve tried reinstalling FCP. I’ve deleted After Effects from my machine. I don’t know what else to do.
    TimR><>
    Don Greening replied 21 years ago 3 Members · 5 Replies
  • Jeremy Garchow
    September 20, 2005 at 11:41 pm
    Do you have ultimatte installed on your machine?
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
  • Timothy Rasmussen
    September 21, 2005 at 12:33 am
    No. I don’t think so…unless it came standard with some other app and I just never knew it.
    TimR><>
  • Jeremy Garchow
    September 21, 2005 at 5:39 am
    Alright, well check your plugins folder in FCP and delete (or move out of the plugins folder) anything that has to do with ultimatte. Also, make sure that there
  • Timothy Rasmussen
    September 21, 2005 at 1:22 pm
    Thanks for the input. Where exactly do I find the FCP prefs to delete them?
    TimR><>
  • Don Greening
    September 21, 2005 at 4:59 pm
    Read all about trashing FCP prefs here:
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    …….and you can get a free program called Final Cut Pro Rescue that does it for you. Do a Google search and it’ll come up.
    – Don
