Activity › Forums › Apple Final Cut Pro Legacy › help FCP No Communication!
  • help FCP No Communication!
    Posted by Eron Otcasek on January 13, 2010 at 6:33 am
    Both in FCP and in the AJA VTR Xchange Application I have no deck control thru the RS-422 cable that runs out of my AJA card (In final cut pro it says No communication) in the AJA VTR Xchange Application it says: “make sure you are connected to the serial port.” I am sure all my cables are tight. This is the first time I have used this Aja card(cable) cause I’ve just set up a new FCP station. 2.66GHz Quad-Core Intel and I have installed the G-Tech 4-Port, PCIe x4 RAID Controller into slot 4….Aja LHi card in slot 2
    David Bogie replied 16 years, 8 months ago 2 Members · 2 Replies
  • Eron Otcasek
    January 13, 2010 at 4:52 pm
    Problem solved!!!!!! The Aja breakout cables can fit into the back of the mac upsidown, but the Aja logo should be on top!!!! Hope this will help someone else!
  • David Bogie
    [Eron Otcasek] “This is the first time I have used this Aja card(cable) cause I’ve just set up a new FCP station. 2.66GHz Quad-Core Intel and I have installed the G-Tech 4-Port, PCIe x4 RAID Controller into slot 4….Aja LHi card in slot 2”
    You need to talk to AJA, don’t you?
    I think there’s an AJA forum here on the cow.
    bogiesan
