Activity Forums Apple Final Cut Pro Legacy HELP! Exporting HD for WEB.
  • HELP! Exporting HD for WEB.
    Posted by Jeremy Donaldson on April 3, 2009 at 3:40 am
    I have just finished my edit and need to export my footage for the web.
    Shot on Canon XH-A1 1080i/24f (Edited 1080p/24)
    New to exporting HD and need step by step exporting help.
    Will be exporting for HD WEB use.
    Jerry Hofmann replied 17 years, 5 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    April 3, 2009 at 1:17 pm
    H.264 (download presets for the Web) is likely your best bet. If you keep the frame size the same, the quality will be great at the cost of download times… the higher the quality, the larger the file so the longer it takes to download. Try using one of the presets in Compressor for this… it’s pretty simple. There’s really no difference in what you’ve done in the past when compressing HD for a web delivery, the procedure is the same, the file size is larger…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
