Activity Forums Apple Final Cut Pro Legacy Help! ERROR MESSAGE
  • Help! ERROR MESSAGE
    Posted by David Ashley on October 14, 2009 at 2:28 pm
    Hello,
    I’m having problems opening up my copy of Final Cut Studio 2.
    It’s been working fine for some time. I reinstalled my decklink software for my blackmagic card and this is the error message it gave me when trying to start up Final Cut:
    ‘Final Cut Pro requires that your system have a quartz extreme capture video card’
    (see atached image)
    I cant even use Final Cut anymore, can anyone help? I just need to use final cut again, I dont care abotu the blackmagic.
    Thanks.
    Dashley
    Craig Russillroy replied 16 years, 10 months ago 2 Members · 2 Replies
  • David Ashley
    October 14, 2009 at 2:32 pm
    The Atached error…
    Dashley
  • Craig Russillroy
    October 14, 2009 at 3:16 pm
    I had this on my old Oct Mac Pro –
    Turn the machine off unplug it from the computer and see if the grachic card is seated correctly … if that is fine plug the old girl back in and hold the power swittch on for 5 – 7 seconds – you will either hear a cry for help in the way of a loud beep or the led on the power switch will flash – this is a PRAM reset – this flashes out all the nastys that can cause issue… failing that trash FCP preferences and see how that goes ..
    Good luck and gods speed !
    MINTedit
    Editing – VFX -Digital Signage – Digital Pipeline Solutions
    MACproo – All the bits and bobs
