Activity Forums Apple Final Cut Pro Legacy HELP (emergence) with exporting video & sound
  • HELP (emergence) with exporting video & sound
    Posted by Alieninnovation on October 18, 2005 at 4:34 pm
    could somebody help me out with FCP or Compressor?
    I need to export footage in a mpeg2 but in Wide 1024 x 576 square pixel Data Rate 6-8 mbit and the sound needs to be in 48 khz Stereo and it should be multiplexed.
    But it all needs to be one file.
    I can’t get it to go.
    Help!
    iMac G5 17″
    Final Cut Studio
    Alieninnovation replied 20 years, 11 months ago 2 Members · 2 Replies
  • Pduhamel
    October 18, 2005 at 5:53 pm
    I may suggest you to export your project as a quicktime file first from FCP (Unselect the Self-Contained Movie). Close FCP to save CPU usage and open Compressor. When you import your quicktime file, you will see different MPEG2 presets. I may suggest you to select the preset that will be Widescreen and High Quality with the amount of minutes closest to your project (By default, it will be 60, 90 & 120 mins). It will create two files, 1- AIFF PCM Audio file 2-M2V MPEG2 Video file. If you want to tweak the settings furthermore, double-click on the preset chosen and adjust as you wish and simply submit the job for processing.
    Hope it will help,
    Have a nice editing!
    Rayden
    Final Cut Pro 4.5 HD user
  • Alieninnovation
    October 18, 2005 at 7:07 pm
    Hey,
    thanks but I can’t adjust the frame size when I have mpeg2 selected the Size adjustment is ghosted out.
    iMac G5 17″
    Final Cut Studio
