Activity Forums Adobe After Effects [help] effect messes up with a text mask ???
  • Peter Van der zee
    January 9, 2008 at 12:30 pm
    What effect did you apply to the text-layer?
    If the effect messes up 3d, try precomping
    That is, put the text and the effect in a 2d comp and that comp 3d in your comp.
    normaly fixes the problems..
    vanderzee.tv
