Activity Forums Sony Cameras help edit 1440×540 ???
  • help edit 1440×540 ???
    Posted by Dimas Indra on June 19, 2008 at 9:52 am
    Hi, i’m new here
    I’m a rookie so this is my question
    I have MXF files that I shoot using sony XDCAM HD 355 with 50fps,(slow motion)
    but why my aspect ratio frame size is 1440×540 and not 1440×1080? and how can I edit it? coz my other shot was at 50i and the frame size is 1440×1080,
    please can you guys tell me what NLE support that 1440×540 setting
    and when I try to resizing it, my picture is full of artifact etc
    when I try to open on Premier pro cs3, with XDcam 1080 project preset, my picture with 50i is in normal frame size, but my slow motion picture the frame size is very small….
    please help….
    thanks
    Robert Dexter replied 18 years, 2 months ago 3 Members · 3 Replies
  • Rafael Amador
    June 19, 2008 at 10:14 am
    Make a try:
    Duplicate a clip and open it with QT.
    Comm-J (Properties)> Video Track> Visual setting
    Change the values by 1440×1080.
    Un check Preserve aspect ratio.
    Save and import to FC.
    See how comes now.
    Rafael
    http://www.nagavideo.com
  • Dimas Indra
    June 20, 2008 at 4:06 am
    ok thanks, I will try
  • Robert Dexter
    June 23, 2008 at 1:17 pm
    If you’re not on a Mac, this doesn’t help you, sorry… but for what it’s worth, the workflow with Final Cut Pro is exactly the same for 1440×540 clips as everything else. It works just fine.
    You can browse and preview these clips in XDCAM Transfer and import them to QuickTime movies. When you open them into Final Cut Pro they show at the same size/aspect ratio as 1440×1080 clips that you might want to edit them with. Only difference in FCP is that these clips always show the ‘red line’ (needs rendering) on the timeline.
