Activity › Forums › Panasonic Cameras › Help! DVX shooting Black!
Posted by Alexander Lee on August 22, 2005 at 3:27 pmHello,
I
Noah Kadner replied 21 years ago 2 Members · 1 Reply -
1 Reply
Noah Kadner
August 22, 2005 at 4:14 pmOh scary! I’ve never seen that happen. The cam might be damaged to the point of needing pro repair. One thing you can try is to reset the scene files to factory. You do this by scrolling down through the settings until you see init- select it and say yes. It may also simply be wet inside. So you may want to put it in a dry place and let it sit unpowered for a day or two and then try again.
Noah
