Activity › Forums › DVD Authoring › Help – DVD glitches
  • Help – DVD glitches
    Posted by Erich Drazen on January 24, 2007 at 6:05 am
    I have been using Verbatim DVD-R discs for years without any problems. Recently, I have started experiencing glitches on the DVDs I have been burning. I purchased some Verbatim DVD+R discs and tried burning a recent project (where I had glitches on the DVD-R discs) and still had glitches. I pulled an older blank Verbatim DVD-R disc and tried burning the same project, and that played fine with no glitches. I am guessing that I just need to find a new reliable brand of recordable DVDs and I need some suggestions quickly, as I have a building backlog.
    Thanks.
    Dorit Grunberger replied 19 years, 5 months ago 4 Members · 4 Replies
  • Don Greening
    January 24, 2007 at 6:28 am
    Taiyo Yuden DVD-R. The best of the best.
    – Don
    “Please take a moment to fill out your profile, including your computer system and relevant software. Help us help you.”
  • George Wing
    January 24, 2007 at 1:28 pm
    Did you burn both discs at the same speed? Of were the newer discs burned at a faster speed (vs a limitation of the older disc)? Sometimes burning at slower speeds can help…
    Also, what bitrates are you using for your DVD (Video+Audio)? Try not to go too high, as that might cause glitches (and perhaps a high-bitrate coupled with the new media was enough to show the glitches).
    Regards,
    George
  • Erich Drazen
    January 24, 2007 at 3:30 pm
    I use Sony DVD Architect 2 and burn the discs with a bitrate of 6Mbps (or lower). Also, I’ve burning the discs at the slowest speeds available (1x for DVD-R and 2.4x for DVD+R).
    Erich
  • Dorit Grunberger
    April 12, 2007 at 5:55 am
    hi there
    I too am getting glitches. It’s been quite a while now and it’s driving us crazy. I’m using a G5 pre-intel, with 4GB RAM, and whatever internal DVD burner is in there (pioneer?)
    Anyway, I was starting to think it is the burner itself. what kind of bitrate is too much and how can I adjust it down? and how much can i adjust down and still get quality in a timely fashion?
    thanks in advance
