Activity › Forums › Apple Final Cut Pro Legacy › HELP – DVCPRO HD 720p60 to HDCAM 1080i
Posted by Serac Adventure films on July 11, 2007 at 1:14 amWow, my head is about to explode right now.
I’ve looked on the forum and really couldn’t find the right workflow for this
OK, i have a timeline that’s DVCPRO HD 720p60 and I need to layback on HDCAM 1080i.
i have FCP 6 and a Kona 3
I was able to take a clip of the DVCPRO HD 720p60 and use cinema tools to make it 29.97 – and then the DVCPRO HD 720p60 sequence automatically made the editing timebase 29.97. (don’t ask me how) and then i know my kona will take that and convert to 1080.
how do i do this with a 14 minutes sequence? can i media manage the 59.94 based timeline or do i need to use cinemal tools at some point? how will that effect the audio, i need discrete.
any help would be much appreciated
-dave
Serac Adventure films replied 19 years, 1 month ago 5 Members · 10 Replies -
Shane Ross
July 11, 2007 at 1:29 amWhy are you messing with any of that? The Kona 3 will cross convert 720p to 1080i on the fly as you output. What do you need? 1080i29.97 from 720p59.94? No problem.
What settings to change? Not sure…I do this at a post facility. Next time I’ll arrange to sit in the drivers seat. But I know you do this thru the Kona Control Panel.
Shane
Littlefrog Post
http://www.lfhd.net -
Walter Biscardi
July 11, 2007 at 2:09 am[Serac Adventure Films] “OK, i have a timeline that’s DVCPRO HD 720p60 and I need to layback on HDCAM 1080i.
i have FCP 6 and a Kona 3”
You do this in realtime using the Kona 3 Control Panel. Leave the 720p timeline alone in FCP and leave FCP in the Easy Setup for AJA Kona 3 720p/60 DVCPro HD
In the Kona Control Panel
Primary Output – set to 1080i/60
Secondary Output – set to 720p/60
Kona will cross convert the 720 to 1080i in realtime to the HDCAM deck and it will be pristine. We’ve done it here and it works perfectly.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Federico Prieto
July 11, 2007 at 2:16 amWalter: can you tell me some about up conversion with hardware from SD to HD? How it works? Get we a better quality than using software? Why?
Tia
July 11, 2007 at 12:34 pmYes, the Kona will convert the 720 to 1080 – but in the final cut pro timeline, the TC goes up to ;60 frames, whereas I need it to go up to ;30 frames. Just like a 24p timeline goes up to :24 before turning over to the next second.
Gary Adcock
July 11, 2007 at 12:53 pm[Serac Adventure Films] “Yes, the Kona will convert the 720 to 1080 – but in the final cut pro timeline, the TC goes up to ;60 frames, whereas I need it to go up to ;30 frames. Just like a 24p timeline goes up to :24 before turning over to the next second.
“HD is all 60 frames ( 720p) or 60 fields ( 1080i) for this workflow
1080 29.97 is a different way to say 60i (29.97 frames x 2 fields is 59.94)
the timecode will match what you set when you black and code the tape on the HDcam deck.This is the same process we all use and I have mastered literally 100’s of tapes in the very same workflow.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows -
July 11, 2007 at 1:01 pmgreat – so when i go to edit to tape – even if in my final cut pro timeline if i’m at 1:10:15;59 – if my tape was coded at 29.97, my deck will be at 1:10:15;29. I’ll try it today. Thanks!
Gary Adcock
July 11, 2007 at 1:24 pm[Serac Adventure Films] “so when i go to edit to tape – even if in my final cut pro timeline if i’m at 1:10:15;59 – if my tape was coded at 29.97, my deck will be at 1:10:15;29. I’ll try it today.”
BE SURE you calculate for difference between the DF 1080i TC vs NDF TC for the 720p material.
gary adcock
Studio37
July 11, 2007 at 1:26 pmand by this you mean? The total length will change or something.
Gary Adcock
July 11, 2007 at 2:29 pm[Serac Adventure Films] “and by this you mean? The total length will change or something.”
720p in FCP uses non drop timecode.
1080i60 uses drop frame timecode for most deliverables.the length does not change, the counting does.
gary adcock
Studio37
July 11, 2007 at 5:43 pmWell, so i went in to layback this morning.
with my aja kona dvcpro hd 720 59.94 sequence (wouldn’t let me make it DF in sequence settings) – told the kona to make it 1080i. Picture is no problem, but couldn’t get it to edit to tape. It would just hang a couple seconds before the edit ‘in’ point and not start. give some servo lock error. I striped the tape both DF and NDF and tried it both ways.
i tried my 1080i pro res timeline to the tape and it worked perfectly.
is there any ‘eureka’ here?
