Activity Forums Adobe Premiere Pro Help creating a clip for Large screen projection
  • Help creating a clip for Large screen projection
    Posted by Shrinivas Ananthanarayanan on April 12, 2010 at 7:21 am
    hi
    need some help creating a clip for a large screen projection
    The clip is basically in a slideshow like format ..text and images ..that im dropping into a sequence in Premiere with fades inbetween them.
    the size of the screen is 16 feet in width and 12 feet in height.
    a coupla questions :
    what would be the minimum screen size i’d need to set in PPro for it to play without pixelating ?
    what should be the minimum resolution for the images i use ?
    also what would be the a good export format ?
    thanks !
    sh
    Brian Louis replied 16 years, 5 months ago 4 Members · 5 Replies
  • Brian Louis
    April 12, 2010 at 9:13 am
    What’s the resolution of the projector you are going to use?? Match your settings to it.
  • Jon Barrie
    April 12, 2010 at 9:23 am
    What format to export to will be dictated by the way it will be played to the projector.
    If you have a PS3 you could have a full HD MPEG-2 or H.264 running from a file not a BluRay DVD. But if the only playback device you have is a DVD player then you are limited to DVD resolution.
    A laptop could be your playback device, but you will need to test it and how the laptop performs with a HD file while being connected to a high resolution external monitor (projector). There might be issues with bandwidth keeping up.
    Some more info in the device direction would go along way to find the best answer/s for you.
    – Jon Barrie 🙂
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
    http://www.suiteskills.com
  • Mark Bowes
    April 12, 2010 at 9:32 am
    when you say Large screen projection,
    do you mean, multi projection or just a single projector on a big screen ?
    Mark Bowes
    system
    Premiere Pro 3.2
    Matrox RT.X2
    Sony HDV-M25AP VT
    Sony DSR-45AP VT
    Sony J30 VT
    Sony HDV-Z1E Camera
    twin P4 3 gig
    4gig ram
    8tb storage
    and a very old Panasonic Mii (somebody must still use it)
  • Shrinivas Ananthanarayanan
    April 12, 2010 at 11:56 am
    Hi
    much appriciate the quick replies .. ! 🙂
    it is a single screen . back projection. need to get the specs of the projector from the guys im getting it from …
    i reckon a DVD player or laptop is all that we have.
    the images i have at my disposal are 300 DPI.. and a minimum of 2000 pixels on their longer sides. would these be ok when resized to fit the frame size of 1920 x 1080 ? i mean will they hold up when projected or would that depend on the export settings ?
    i’ve created a timeline for the 16 ft x 12 ft screen
    1920 x 1080
    25fps
    and a 1.333 aspect ratio.
    am i doing something wrong ? would like to be sure before i render it out … 😀
    Thanks much ppl !!!!
  • Brian Louis
    April 13, 2010 at 1:00 am
    [Shrinivas Ananthanarayanan] “the images i have at my disposal are 300 DPI.. and a minimum of 2000 pixels on their longer sides. would these be ok when resized to fit the frame size of 1920 x 1080 ? i mean will they hold up when projected or would that depend on the export settings ?
    1920 x 1080
    25fps
    am i doing something wrong ? would like to be sure before i render it out … :D”
    Once again you need to know the specs of the projector, and how it scales, right now you have a 16’x12″ which is a 4:3 screen that you are making a 16×9 project for, you are using a 1920×1080 preset that uses sq pixels, but you are using a 1.3 aspect ratio, the thing is to find out what your equip. is capable of before you start the project.
