HELP!-Correcting a shutter speed error
First, thanks to all who have helped me with the few problems I’ve encountered after getting back in the biz and adapting to the new “stuff.”
Here is one I’m hoping someone may have some advice for:
Some of the material shot for a big project in HD-24p was accidently shot in a shutter speed of 1/24. The results are that movement is blurred. When played back in the camera’s playback, it doesn’t look too bad, but it seems to be enhanced when captured using Vegas Pro 8. I’m “assuming” the compression is enhancing it, but not sure.
Anyone have any advice on how to at least reduce the blurring caused by these issues? Are there some settings prior to capture that should be set in Vegas that may help?
Thank you very much!!
