Activity Forums Adobe Premiere Pro HELP! Constant crashing when trying to export project
  • HELP! Constant crashing when trying to export project
    Posted by Rachel Jenks on January 7, 2010 at 1:56 pm
    Source File is a 1280 x 996 (29.97, square pixels) wmv file created through Go To Webinar, which I then edited in Premiere Pro CS3.
    Project is 720 x 480,”Fit”, 29.97, square pixels.
    Original audio was poor quality and contained re-takes, so I used “render and replace” to edit audio in SoundBooth (CS3).
    Edit divides the source file into two parts. Part one of the edit is about 40 minutes, Part 2 is roughly 20 minutes.
    Edit is pretty basic, some crossfades, a handful of extra images, etc.
    I have been able to render the project within Premiere. However, for some reason, I cannot seem to get it to export the project without crashing.
    It gets about 60% through, then crashes. I’ve attempted to fix the frames where the crash occurs, but it seems to be inconsistent. I fix one, and then it crashes at another frame the next time.
    Export settings are 720 x 480, fit, 29.97, square pixels, Video – “constant”, 2 passes, Image Quality max, Maximum bitrate 256 (though I have tried higher as well, and that also crashed). Audio – “constant”, 2 passes, 48 stereo CBR.
    I have tried exporting a variety of ways, including Export – Movie – Quicktime.
    Desired file format is wmv or other You-Tube compatible format.
    Thoughts or suggestions??
    Rachel Jenks replied 16 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
