Activity Forums AJA Video Systems HELP!: Composite Frame Rolling & Synce Probs
  • HELP!: Composite Frame Rolling & Synce Probs
    Posted by Dan Lachevre on February 28, 2006 at 11:07 am
    Hi All
    Just set up a FCP sytem on a Quad G5 with a Kona LH card [using the latest drivers] and have a problem with frame rolling from a composite input. I’m digitising from Pal VHS using the KONAs standard 625i DV capture setup and keep getting an intermittant frame rolling problem. The KONA manual says a REF is not really needed but I’m wondering if that is the problem. The frame is not rolling either on the tape or on the monitor that has a another direct line out from the VHS
    I have altered the PAL rez in the capture settings from 100% to 25% and didn’t think that would make a difference. I’m currently doing a test back at 100% to see if there is a change.
    When I’m not in capture mode and the tape is playing through into the source window it rolls there as well which made me think it was a KONA prob.
    To make things more interesting the audio goes increasingly out of sync by 1 to 2 secs on long digitizes. I suspect it is becasue of these frame rolls. Weird thing is when I set up a H264 codec capture set [I now know it is not a good codec for editing] there were no sync probs.
    Any ideas?
    Thanks in advance.
    Danny
    Robert Ober replied 20 years, 6 months ago 4 Members · 5 Replies
  • Dan Lachevre
    February 28, 2006 at 11:08 am
  • Christopher Tay
    February 28, 2006 at 12:23 pm
    VHS signals are generally very unstable and may be why you are seeing the symptoms. Do you have another composite source that you can feed into the Kona card ? That way you can check if the composite input is working or not.
    -chrispy
  • Bob Zelin
    March 1, 2006 at 3:42 am
    Dan –
    the AJA I/O line has a standard Frame Synchronizer input on it’s composite inputs to stabilize a poor incoming VHS input. I don’t know if the LH has
    a frame sync (I don’t think that it does) – SO, you can either get an AJA I/O, or you can get a nice cheap Datavideo Frame Sync TBC for about $300 from Markertek. This will lock up your unstable VHS sources.
    Bob Zelin
  • Dan Lachevre
    March 2, 2006 at 9:05 pm
    Thanks for the Help Guys.
    I guess an external TBC is the way to go. I was under the assumption the LH had one built in for this sort of thing though. Bummer.
    Danny
  • Robert Ober
    March 18, 2006 at 10:56 pm
    I am having a similar issue capturing from a Hi8 camcorder.
    You fix your sync issue?
    Robert A. Ober
