Activity Forums Apple Final Cut Pro Legacy Help – capturing SD – still having problems
  • Help – capturing SD – still having problems
    Posted by Paul Witcher on February 8, 2010 at 3:33 pm
    Hi Guys,
    I did post something yesterday regarding capturing SD stuff, I think I now have the correct settings??? but I’m getting strange behaviour.
    Settings : format PAL Use: DV-PAL
    Capture settings : Device control : FireWire PAL Capture/Input DV PAL 48kHz
    Then using Capture Now – it captures the footage OK but when I esc it saves the capture as one long clip in the browser, even though there are ten clips in the capture and I get an error message that says the audio sample rate does not match sample rate on the source tape arrrrrr Surely I’m being a knob head here? Can anyone help
    Paul
    Paul Witcher replied 16 years, 6 months ago 2 Members · 2 Replies
  • Todd Gillespie
    February 9, 2010 at 5:00 pm
    Hi Paul,
    The “Capture Now” function just digitize the tape as it’s playing until you hit escape.
    If you want to capture ‘clips’ you would need to use the batch capture function.
    The audio sample rate is due to the tape being record at a lower rate than 48khz. Once you’ve capture it, you can render the audio rate up to 48khz.
    Good Luck,
    Todd at UCSB
    Television Production
  • Paul Witcher
    February 10, 2010 at 5:15 pm
    Hi Todd,
    Thanks for the post, as I guessed I was being a bit of a knob, it was a case of RTFM, things are slightly better using the DV Start/Stop Detect as well, but I may well use the batch capture.
    Cheers Paul
