Activity Forums Adobe Premiere Pro help can’t open projects
  • help can’t open projects
    Posted by Chris Balogh on August 3, 2009 at 1:35 pm
    I have recently updated from CS2 to CS4. The CS2 projects will not open, two things happen:
    IT WILL SAY, PROJECT APPEARS TO BE DAMAGED OR
    IT IS ABOUT TO ALLOW ME TO CONVERT IT, BUT THERE IS NO OPTION TO SELECT YES, NO, CANCEL IN THE WINDOW TO CONTINUE? The window is big enough where normally there are buttons under the question to me as the user to continue converting the CS2 to CS4? The autosave projects will not open either? Help.
    Chris Balogh replied 17 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
