Activity › Forums › Apple Final Cut Pro Legacy › Help, can’t find a card to work for external grading monitor?
Nigel Cooper replied 19 years, 10 months ago 6 Members · 13 Replies
Nigel Cooper
October 13, 2006 at 4:02 pmI have asked Matrox and it dosn’t so I still don’t have a sollution.
Uli Plank
October 14, 2006 at 10:51 amI have a partial solution for you, I just tested this on our Decklink HD Extreme:
I set up a timeline for DVCProHD with 25p, unfortunately I don’t have any HDV25p files and set the video output via Decklink with downscale to PAL 8 Bit. I get a stable image on our professional Sony SD monitor and I can scrub or watch changes on filters. It just doesn’t play, but it’s good enough for color correction.
I can test this with our MXO as well, once it’s back from shooting (about ten days from now).
Hope this helps,
Uli
Nigel Cooper
October 14, 2006 at 5:10 pmThat is a bit further than I got, all I could get is a still frame that did not scrub, I had to jump to another part of the timeline to get the frame to change.
I suspect I might have to settle for this sort of thing.
If you could test with MXO that would be great.
Thanks Uli
