Activity › Forums › Apple Final Cut Pro Legacy › HELP! buried in real time
Posted by Icriddle on October 17, 2007 at 9:03 pmi was just given 9 1hr MiniDV tapes shot standard on a tripod of a mural being created. the camera ‘operator’ has visions of this becoming a time lapse. i know older versions of Premiere can capture 29.97 at a time lapse rate, but is there any NEW solution? anything to save some time.
Icriddle replied 18 years, 11 months ago 4 Members · 5 Replies -
Rafael Amador
October 18, 2007 at 5:14 amAs long as I know, there is not any spacial set in FC to work with time-lapse clips. You record time-lapse and you download like any other fotage.
The speed set in FC only allows to increased 10 times. If you need to speed-up your footage further, you can use the “fit” option. Set an In and OUT point in your time-line and make a fit-edit. Your clip will get the necesary speed to be played with the IN-OUT duration.
Rafael -
Rafael Amador
October 18, 2007 at 5:21 amSorry I click the “post direct” too fast.
I don’t know if i understood well your post. The film should have been shot time-lapse, but was shot normal, so now you must speed it up? Is like that?.
Before when I sayd “fit” I meant “Fit to fill”.
There is a good article-tutorial about this issue:
“Nimle Nimbuses and Swift Sunsets Creating Time Lapse Video” by Ben Bryant in the Ken Stone web-site.
Rafael -
Aaron Zander
October 18, 2007 at 1:57 pm[rafalaos] “The speed set in FC only allows to increased 10 times”
IS that 1000%? Because I just made a clip, that I know for a fact was at 1600%
Boyd Mccollum
October 18, 2007 at 3:19 pm[iCriddle] “i know older versions of Premiere can capture 29.97 at a time lapse rate”
if you are asking if there’s a way to capture the footage as timelapse in FCP, I don’t believe it can do that. You will need to capture all 9 hours of footage.
Also, speed changes aren’t “timelapse”. Timelapse involves shooting a frame of film or video every “x” seconds, minutes, hours, days, etc. I’ve never needed to backend this in FCP, so I don’t know what the short cuts might be, but you could select what interval between frames you want and delete all the footage in-between. Time consuming, but that’s the genesis of the reason why we try to avoid “fixing it in post”.
Icriddle
October 23, 2007 at 4:18 pmyeah just as i figured, not much i can do.
thanks guys for your helpful suggestions.
next time i imagine i should just shoot it.
