Activity Forums Maxon Cinema 4D Help !! – Boole Object freezing render
  • Help !! – Boole Object freezing render
    Posted by Andy Stokes on April 18, 2006 at 3:13 am
    Hi all,
    I have a scene containing a few boolean objects. I have used simple cubes to in essence wipe on each object. I have been working in low L.O.D mode whilst in the workspace and everything is working well. However, once I try to render the scene it hangs at the “preparing” stage.
    I experimented with the render options’ level of detail and found it’ll work if I set it at 60%. Only problem is, this doesn’t look so great as some objects are quit curved.
    Any suggestions on anything I could try to fix this ? Need to get this project rendered ASAP.
    Cheers,
    Andy
    Adam Trachtenberg replied 20 years, 5 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    April 18, 2006 at 4:32 pm
    If “High Quality” is checked in your boolean objects, you might try unchecking that. Sometimes the old ways are the best. 🙂
