Activity Forums Adobe Illustrator Help Bevel 3d effect
  • Help Bevel 3d effect
    Posted by Arthur Durand on March 26, 2024 at 1:19 pm
    Hello friends
    So when applying a bevel effect in the 3d panel the edges of the bevel do not align on my 3d object. So I would like to edit them manually. Now when you put it into wire frame you can see how the bevel would look like and you can edit the edges of the bevel. Only then you can’t export it anymore as an OBJ for further processing in blender. You can only export to SVG, PNG, etc… But you need OBJ to keep the 3d shape. Is there a way to edit the edges of the bevel and still keep the obj?
    Oscar Polanco replied 2 years, 5 months ago 2 Members · 1 Reply
  • Oscar Polanco
    March 29, 2024 at 8:15 am
    In order to export a 3D object you have to go to window / Asset Export and this will open the Assets export tab.
    Now you must select your ·D Object and drag and drop to the Asset export window. Then click on Export setting in the same window and from there you can select multiple formats including OBJ format. After that just click export and you can save the 3D object as an OBJ file.
