Activity Forums Compression Techniques Help best PP 1.5 plugin to encode DV projects to mpeg w/ auto effects —fed up with AME
  • Help best PP 1.5 plugin to encode DV projects to mpeg w/ auto effects —fed up with AME
    Posted by Squashky on June 30, 2006 at 12:20 am
    Hey
    1) i need an encoder plugin that will encode dv projects at decent speeds with effects on it like auto color and such. AME is just basically useless i have tried every thing to get it to work but it just doesn’t for me w/ anything i do. i have a budget of less then 200. is that enough for a decent one. could it have a batch rendering where i could say render these 4 projects and wake up the next morning and have them done? The files are 2 hours long and have 1-2 auto filters on them. i have a p4 3.4 @3.6 2 gb and will have a p4d 3.0@3.8 2gb I have looked at procoder basic is it any good or is procoder 2.0 worth the nice price tag.
    2) If i can’t get a renderer that will render the auto filter are there alternative auto filters that AME can handle it works fine w/o them but i really like to use them without having to go through the 50 some odd clip and set levels for each.
    thank you for the help
    Charles Simonson replied 20 years, 2 months ago 3 Members · 2 Replies
  • Ben Waggoner
    July 3, 2006 at 6:39 pm
    ProCoder 2.0.2 is pretty great, and works as a Premiere Pro plugin.
    That said, if you’re still on 1.5, have you considered upgrading to PPro 2.0? Much improved version of AME in there.
  • Charles Simonson
    July 3, 2006 at 9:29 pm
    As well, ProCoder Express may be exactly what you are looking for. It has many of the features that its big brother has (the DV portion will definitely have you covered) for a lot less. I don’t recall its batch capabilities however.
    Also, MainConcept sells a good DV encoder for only $49.
