Activity Forums Apple Final Cut Pro Legacy HELP!!! best compression method from FCP
  • HELP!!! best compression method from FCP
    Posted by Jeff Newton on April 5, 2006 at 2:48 pm
    My clients are showing up in a few hours so I am seeing if someone can help me with this rather quickly….I am going to output my final cut of a spot that I just did today to show my client…the one thing that they mentioned on my second draft yesterday was that it was pixelated…I used compressor but I think I might be doing something wrong.
    I shot the project in 24p 2.3.3.2 with my XL2. The spot is going to start on the web with the possibility of going to television.
    My main concern as of this moment is the web compression…MPEG4? but at what setting…I dont care how big the file is…the spot is only 45 seconds so even at it’s highest I am okay with it being larger.
    Thanks, Jeff.
    Jeff Newton
    https://www.jeffnewton.com
    Gunleik Groven replied 20 years, 5 months ago 2 Members · 1 Reply
  • Gunleik Groven
    April 5, 2006 at 3:55 pm
    for web h.264 seems to give beautifull results.
    I’ve recently bought BitVice from http://www.innobits.se for mpeg2 encoding.
    Stunning results compared to compressor.
    (takes some more time, though)
    Gunleik
