Activity › Forums › Apple Final Cut Pro Legacy › Help! .AVI files imported into FCP?
  • Help! .AVI files imported into FCP?
    Posted by Jonathan Burks on January 26, 2009 at 3:23 pm
    I am working with some .AVI files and I need to make simple edits, but when I render them out in Final Cut Pro the playback is terrible, or I get a codec error. Is this type of file supported by Final Cut Pro and is there a setting I need to change to work with them? Or is there a way I can convert the .AVI files into something better suitable?
    Please Help!
    J. Burks
    Elijah Lynn replied 17 years, 8 months ago 3 Members · 4 Replies
  • Dennis Leppell
    January 26, 2009 at 3:25 pm
    recompress them with compressor…..don’t know the sequence specs you’re working with, but DV NTSC should work
  • Jonathan Burks
    January 26, 2009 at 3:28 pm
    Is Compressor a separate program?
    -Sorry, I’m new to this whole Video Editing thing
  • Dennis Leppell
    January 26, 2009 at 5:43 pm
    it should have been installed when you installed FCP. Check your applications folder.
    Also, read this. https://support.apple.com/kb/HT1536
  • Elijah Lynn
    January 28, 2009 at 11:13 pm
    You can rewrap them with Mpeg Streamclip. I forget exact method but I did it to a bunch of clips that I shot with a Firestore FS4-HD and had it set to AVI type 2 and actually needed Quicktime.
    Although it is odd, I have been playing with some stock footage I purchased from Footage Firm and it is all in AVI format and after the message FCP gives me the footage works great in the timeline.
