Activity › Forums › Blackmagic Design › [HELP] Audio out of sync!!! ..it’s QUICKER than video!
  • Master Of desaster
    November 28, 2005 at 9:23 pm
    Hi Andrew,
    I try this test. The Deck and Multibridge are isolated from the network. Then I start all machines. I do this test 3 times without restarting the machines. My subjective feeling is that the first and second edit has a 1-frame offset from the beginning till end. The third edit was more async, around 3-5 frames, but the start was maybe 1 frame and how longer it runs, the audio goes more out of sync,
    @Paul
    I’m also frustrated but I like to work with the BM & PPro combination and I hope the ghosts from BM will help us!
    R
  • Sameer Shrivastava
    November 30, 2005 at 9:58 pm
    thanks for sharing everybody and thanks to R
  • Helio Ricardo
    December 6, 2005 at 11:15 am
    Is there any solution to this problem? I have the BlackMagic DeckLink SD, started a project NTSC 10bit.
    I started with a big project (1+ hour of video), and it went out of sync. So, I tried a smaller project keeping takes of 3 to 4 minutes and it worked. I started editing, at the first Dissolve it started getting out of sync again.
    I found this forum, and would like to know if there is any new solution. I
Page 2 of 2
