Activity Forums Adobe Encore DVD help! audio in the menu stops playing
  • help! audio in the menu stops playing
    Posted by Ryan Santos on March 27, 2007 at 4:02 am
    I edited my “still menu” in after effects. AE generated a 4 second .avi that I linked to my “still” menu. The actual still clickable menu, which has an audio background, has a 3 minute duration. When previewing, the audio stops playing after 4 seconds. I’d like the audio to play for the whole 3 minute duration of the menu. Is that possible? I’m reaching my deadline and it’s keeping me from burning the discs. Thanks.
    Neil Wilkes replied 19 years, 5 months ago 2 Members · 3 Replies
  • Neil Wilkes
    March 27, 2007 at 6:04 pm
    If this menu is set to Loop, then it is going to cut off as soon as the image sequence ends.
    Please remember that in DVD-Video, you are always going to be graphically dominant, Audio Subservient.
    This means that the image or movie or still is always the “lead” item.
    So a 4 second AVI set to loop will play the AVI, then loop – and it WILL cut the Audio short at multiplex. There is no way to avoid this unless you do not want the menu to loop.
    A possible workaround involves a little lateral thinking, and you could try this:
    A – Set your menu to the full 3 minutes, including Audio by extending the final frame to go to the length of the Audio file.
    B – Set the first 4 seconds to go into a still menu, with your 3 minute Audio file.
    Set the end action of this still menu with the Audio to revert back to the initial 4 second video clip.
  • Ryan Santos
    March 29, 2007 at 12:50 am
    Sorry, I’m a bit confused with letter B. Can you explain it a bit further? Thank you very very much!!!
  • Neil Wilkes
    April 1, 2007 at 12:40 pm
    I’ll try.
    If I am reading you correctly, you want the full 3 minute Audio file to loop with your menu, yes?
    Try this:
    Menu 1 – The 4 second one that After Effects created.
    Menu 2 – the final frame of the After Effects menu, as a still, with your full 3 minute Audio file.
    Set the end action of Menu 1 to go to Menu 2, and set Menu 2 to loop.
