Help – Attack of the ever growing rendered file size
All,
Please help. I just recently purchased Vegas MS+DVD Arch Platinum Ed. I am trying to create a DVD with menu’s with a video file created using the Hauppauge WinTV PVR USB 2.0 (hardware) converter.
I recorded the video using WinTV and the associated Win2000 software using the DVD Extended play (720×480 4.4Mbits/sec 48.0kHz Stereo) that creates an *.mpg file. This file is 4.1 Gb in size.
There are a couple of problems. All I really need is to be able to get this video into the multi-menu DVD Arch format with about 400Mb of extra stuff so they can be burned onto a 4.7Gb DVD. In other words, when DVD Arch imports the file, it needs to see it as < 4.3Gb. So, the issues are this: 1) I must make edits to this file, but they are all trimming and deleting edits; no addition vid. When I import this DVD Extended play file of 4.1 Gb into Movie Studio and attempt to attempt to render before any editing (just to see what the output file size would be), it tells me the 4.1Gb file is now 6.3Gb. This is a problem. Render format is MPEG-2, DVD NTSC and/or DVD Architect format NTSC video only (file sizes are identical with and without the audio) 2) After editing, i've been able to reduce the rendered file size to 4.1 Gb. Great, right? Except that when I import the newly rendered DVD NTSC or DVD Arch format NTSC video only file into DVD Arch and open the DVD Optimize window (under File menu), it tells me that 4.1Gb file is 5.8Gb in DVD Arch. If I could cut down just one of these two file augmentations, I could get the video onto the DVD. Heck, the video is only an hour and 15 minutes long recorded in extended play using the Win2000 software from Hauppauge. Shouldn't I be able to get that video onto a 4.7Gb DVD? Please help!!!!!!!!! Thanks, Scott
