Activity Forums Adobe Audition Help and advice needed for recording a charity single on Audition…..
  • Help and advice needed for recording a charity single on Audition…..
    Posted by Richard Jay on November 11, 2006 at 11:31 pm
    Hi, I am fairly new to using Audition as I mainly do video work. I am trying to record a single for my niece that she intends to sell for charity.
    Could anybody tell me or point me to a link with a tutorial perhaps, that will allow me to:
    1. Play a backing track from my PC through 2 or 3 pairs of headphones while I am,
    2. Recording them singing through a microphone connected to the line in.
    3. Allow me to playback through the headphones the backing track and them singing and record a third track of them singing more vocals.
    4. I need to be able to for example, delete track 3 (extra vocals) and let them do it again so everytime I record I need to to just record the mic and not the backing track and the mic etc.
    I have a Windows PC, Dual Xeon 2.8Ghz, 2GB, Sound Blaster Audigy 2 sound card with line out, line in and mic in, a Behringer Eurorack UB2222FX-Pro mixing desk. If you think I need any extra stuff I have CD-Players etc. and pretty much every combination of leads to connect everything to everything (I just don’t know how!)
    Also, am I best adding reverb to the vocals on the mixing desk before going into the PC or putting it on with Audition afterwards???
    I really appreciate any help on this at all.
    Cheers
    Richard
    Willie Toth replied 19 years, 9 months ago 2 Members · 11 Replies
  • 11 Replies
  • Richard Jay
    November 11, 2006 at 11:50 pm
    Sorry, I forgot to mention – should I let them hear themselves singing through the headphones aswell as the backing track or just the backing track and if I should – how do I do it??
    Richard
  • Willie Toth
    November 12, 2006 at 1:18 am
    Richard,
    OK I will attempt to help you here but I would also suggest reading the help file on a multi track sessions … The headphone issue first … You need to rent purchase or borrow a headphone amp, Here is a link that may help https://www.musiciansfriend.com/product/Behringer-MINIAMP-AMP800-4Channel-Stereo-Headphone-Amplifier?sku=182040 this will give you the ability to have multi headphones on one output … ALWAYS, I repeat ALWAYS record dry and add any effects after … The reason, if you record with effects you can’t change it … For the basic info on a multi track sessions again I refer you to the help section I can’t suggest this strongly enough it will make helping you much easier … I check the site a couple of times a day so I will help where I can …
    WILLIE
  • Richard Jay
    November 12, 2006 at 11:23 am
    Hi Willie, Thanks for your reply. I think I will buy one of the Behringer AMP800 headphone amps as that will come in useful again!
    I will read the help section on Audition when I get home later, but in the meantime – is my Soundblaster Audigy capable of doing this job by playing and recording at the same time and multi-tracking as somebody had suggested it might not and I should get a new soundcard, they suggested the M-Audio Audiophile 2496 sound card. Would this be better quality and do the job better than my Audigy?
    Thanks again Willie, I will come back after reading the help section on multitracking.
    Richard
  • Richard Jay
    November 12, 2006 at 11:42 am
    Sorry Willie, just thought of another question….
    My Mixer, Behringer UB2222FX-Pro says it has a 2/2bus, is this the same as an alt3-4 bus? Can I listen to my pc and just send one channel back to the pc to be recorded? The link for mixer is https://www.behringer.com/UB2222FX/index.cfm?lang=ENG
    Cheers
    Richard
  • Willie Toth
    November 12, 2006 at 3:52 pm
    Richard,
    OK, your soundcard is just fine, I used a basic soundblaster card for a long time just use the line in and outs … I helped a friend set his studio up with the 3/4 board and it does a nice job … After reading the manual it looks like you should plug the headphone amp into the aux sends 1 refer to 2.3.2 of your manual … The difference between your board and the 3/4 is that you don’t have as many signal paths that you can use … Hope this helps ………… WILLIE
  • Richard Jay
    November 14, 2006 at 11:57 am
    Hi Willie,
    Ok, I have now recieved my Behringer HPhone Amp!! Lovely looking piece of kit.
    I am having trouble connecting it. I have plugged a pair of headphones directly into the aux send 1 to see exactly what comes out of there and I hear left and right channels combined in my left ear and nothing in the right. Can you see in the manual a stereo output for this application? I have a stereo to 2 mono jack lead and 2 mono to 2 mono jack lead so I can connect either to the headphone amp. I do have a headphone socket on the desk but if I adjust my monitor levels or what is fed to them on the desk this will impact the headphones which ideally I don’t want.
    My other option is to feed aux2 to the right channel of the headphones so you hear both channels in both ears (hope that makes sense)!
    Any ideas?
    Thanks, Rich.
  • Willie Toth
    November 14, 2006 at 12:20 pm
    Richard,
    The manual says it’s a mono out … I don’t see why you can’t use the Aux 2 out as well … The other option would be using the tape out … Either way you should be good to go ………. WILLIE
  • Richard Jay
    November 15, 2006 at 5:40 pm
    Hi Willie
    Thanks for all this help, I couldn’t have got this far without it! And I think I’m nearly there now!
    I have the headphones working and I have the mixing desk connected and I can record tracks etc. while listening to the PC back through my mixing desk.
    I just have a couple more questions, I hope you don’t mind???
    1. For a compressor, should I use Audition (if it has one) or use the one built into my mixing desk for the vocals when recording them?
    2. Should I have just the backing music in the headphones or let them hear themselves singing aswell as the hearing the backing music?
    3. Can I output the track being recorded back to the mixing desk while it is being recorded to play in the main mix and how? At the moment, while a track is being recorded I can only hear the other tracks that have been recorded and the backing music playing – does that make sense?
    Thanks again
    Rich
  • Willie Toth
    November 16, 2006 at 1:34 am
    Richard,
    Outboard compression is a must on vocals, I use a stereo DBX 166 compressor/limitor … I like to run the mic into one channel and then run the output of that channel into the other channel then to my board … You may be wondering why … When a limitor works it’s like a gate opening and closing and if you set it too high you can hear it “breathing” on your recording … Running it like I do means you can get all the limiting and compression you need without hearing it breath … I am not sold on built in compressors but when it’s all you have go for it … Be careful not to compress more then 3 or 4 to 1, even that may be too much … Personally I don’t worry about hearing what I am doing at the time but what is important is hearing what you are playing and or singing to … I think you are ready to really get your feet wet … I’ll be waiting to hear your finished project … Read up on HARD LIMITING it can really be a great friend … Also remember when using verb on vocals unless it is intended for a certain sound you are going for the verb should hardly be detectable when played in the mix … Verb is used to fatten the vocal not overpower the mix …… WILLIE
  • Richard Jay
    November 16, 2006 at 3:17 pm
    Cheers Willie
    My other 2 questions at the moment were:
    1. Should I have just the backing music in the headphones or let them hear themselves singing aswell as the hearing the backing music?
    and
    2. Can I output the track being recorded back to the mixing desk while it is being recorded to play in the main mix and how? At the moment, while a track is being recorded I can only hear the other tracks that have been recorded and the backing music playing – does that make sense?
    Cheers
    Richard
