Activity Forums Apple Final Cut Pro Legacy HELP ?? URGENT why does OFFline RT TL need render?
  • HELP ?? URGENT why does OFFline RT TL need render?
    Posted by Faryar Mansuri on April 22, 2005 at 5:20 pm
    In my third project on FC I decided i didnt need output quality; only a good EDL export.
    So I used the OFFLINE RT DV to JPEG.to digirise..
    This might be a setup issue; but the timeline needs render..
    is this the case, what really is the proper setting? so that the asimple sequence palysback without any rendering.
    thanks
    faryar
    Faryar Mansuri replied 21 years, 5 months ago 2 Members · 3 Replies
  • John Pale
    April 22, 2005 at 5:23 pm
    Sounds like you dropped the offline rt clips in a DV or SD sequence. you need to have both your timeline and capture settings set to Offline RT.
  • Faryar Mansuri
    April 22, 2005 at 5:32 pm
    Thanks John
    you may be right…
    is there a remedy?
    faryar
  • Faryar Mansuri
    April 22, 2005 at 7:07 pm
    Thanks again
    I figured it out
    f
